do i need to get this tuned
Old Sep 6, 2010 | 05:14 PM
zooguy's Avatar
Default do i need to get this tuned
I plan on doing a gears in the rear 3.73's (i got 2.73's) and LT headers and a ORY .... will i need a tune after this ... yes ... but will it hurt my car if i dont get one right away? and if so what will be damaged?
car is basically stock 95 firebird formula
Old Sep 6, 2010 | 05:25 PM
bigj2717's Avatar
No it wont hurt. Your speedo will be off becuase of the gears and you might throw a code if you delete the emissions.
Old Sep 6, 2010 | 05:32 PM
mrchyzy16's Avatar
Old Sep 6, 2010 | 05:36 PM
zooguy's Avatar
any idea how far off the speedo will be?
Old Sep 6, 2010 | 05:42 PM
bigj2717's Avatar
Probably about 10 mph or so
Old Sep 6, 2010 | 05:50 PM
Badazz 97 TA's Avatar
If your car is an automatic it wont shift the way it should. You need to get the shift points changed.
Old Sep 6, 2010 | 05:52 PM
zooguy's Avatar
how do i do that?
Old Sep 6, 2010 | 05:56 PM
mrchyzy16's Avatar
through a tune
Old Sep 6, 2010 | 06:16 PM
zooguy's Avatar
oh boy that sounds like fun
Old Sep 6, 2010 | 08:08 PM
Just send in your pcm to one of the mail order guys. PCM for less, madz28 etc or find a local performance shop
Old Sep 6, 2010 | 10:59 PM
RamAir95TA's Avatar
Going from 2.73s to 3.73s will set your speedo off WAY more than 10mph. You will certainly have shifting issues and a tune is absolutely necessary.
Old Sep 6, 2010 | 11:29 PM
zooguy's Avatar
what do you mean shifting issues? please explain your the 2nd person to say that but what do you mean?
Old Sep 7, 2010 | 12:23 AM
mrchyzy16's Avatar
the car is gonna be bouncing off the limiter trying to shift
Old Sep 7, 2010 | 08:32 AM
because with the shorter gears your car is gonna need to shift at a lower mph. With the 2.73's i bet your first gear goes to like 40mph at full throttle. With the 3.73's it will probably need to shift at a early 30mph. my 3.23's only go to 34mph at 6000rpm. Same with the other gears(2,3 and 4th) along with part throttle shifts like driving normal on the street. With the electronic controlled transmission its 100% necessary to change the shift point tables in the pcm.
a mail order tune isnt that much $$ anyways. It really isnt a big deal at all.
Old Sep 7, 2010 | 02:07 PM
MasterTomos's Avatar
I've seen nothing but good things about Ion/Madz28...I'm definately going with him when I do my tune.
For a gear jump that big, yes it will be necessary.
