What should I look for - Car missing/backfiring
Old Sep 14, 2010 | 07:21 PM
detroit_903's Avatar
Default What should I look for - Car missing/backfiring
95 camaro z28. recently been having a bad/missfiring with occ. backfiring while driving - very bad.. Recently changed the o2-sensors one had lead deposits the other one was really white. --- Car still is missing and backfiring. It's very very rich - so rich it will burn your eyes... What should I look for?? I'm getting a dtc 18/55 code but those were always on in the past when the car ran fine --- need help
Old Sep 14, 2010 | 09:22 PM
pro94lt's Avatar
did you change your 02's in attempt to fix the problem? dtc is for lean fuel, what are your 02's reading? what about fuel pressure? and I hate to say but any miss or strange acting lt1 can be a opti. I'd first check what your 02's are reading, fuel pressure, then plugs and wires.
Old Sep 14, 2010 | 10:51 PM
SoxXpupPeT's Avatar
Chevk for vacuum leaks, burnt plug wires and bad spark plugs. Also you could check your coil
