is an electric water pump worth it
Old Sep 16, 2010 | 10:04 PM
Z28Roxy's Avatar
Originally Posted by shbox
It's possible for anything to break at a moments notice. However, most mechanical pump failures (mainly the bearings) are preceded by leaking out the weep hole and give you some time to take care of it. Not everyone's experience is going to be the same.
Mine was leaking out the weep hole when I got it home. I replaced the pump about 3 years prior because I noticed the leak but this time I was not so lucky. How often do you check for leaks under your car?
Old Sep 16, 2010 | 10:05 PM
Z28Roxy's Avatar
Originally Posted by JoeliusZ28
i pay attention to my gauges all the time, i didnt waste my time with a warning light.
When my mechanical failed I was paying attention to the gauges. I hadn't looked away more than 20 seconds when I saw it had gone from 1/8 to pegged.
Old Sep 25, 2020 | 04:25 AM
JJ Flores's Avatar
Originally Posted by WS Sick
ive had my meziere for about 7 years , I wired a red failure light in the WP circuit, gets your attention.
How did you manage to make that is ther a way I can do it my self or would I need to go to a shop?
Old Sep 25, 2020 | 09:45 AM
SS RRR's Avatar
Village Troll
There was a schematic floating around years ago called the "watchdog" diagram. Bleep bloop that in the search box and see if you can find it...
Old Oct 20, 2020 | 08:30 AM
Alejandro Guerrero's Avatar
https://ls1tech.com/forums/lt1-lt4-m...dog-quick.html
Old Oct 20, 2020 | 08:36 AM
Here it is without the watermark
Old Oct 25, 2020 | 05:58 PM
SRZ's Avatar
SRZ
CSR pump and it's been running since 06'. I will buy another one when the time comes and mine is wired to a LED and 100db speaker.
