Bore Tolerence(sp?)
Old Jan 27, 2004 | 09:28 PM
Just Floor It's Avatar
Default Bore Tolerence(sp?)
How tolerant are the cylinder walls of an LT1??? How do they compare to the LS1?? From what I understand, LS1s can only stand a .010 hone....So what about LT1s??
Thanks
Old Jan 27, 2004 | 10:16 PM
Vendetta's Avatar
LT1s are easily bored to .30 over (that's why there are so many 355s running around), not sure about much more (def no more than .60), but they take it better thanks to the iron block. ls1s have to be resleeved, as you said...
Old Jan 28, 2004 | 12:02 AM
ChrisB's Avatar
You can do a 30-40 over with virtual impunity, probably a 50 over, but at 50+ over I would get the setup sonic checked, esp. if you are going to invest in anything expensive (splayed mains and such). A few people have done 4.1 bores, but that's pretty exotic, and definitely pushing it. There just isn't a bunch we can pick up in bore, most of our gain will be through stroke.
Old Jan 28, 2004 | 01:59 AM
Vendetta's Avatar
That about says it...
