help needed
Old Sep 22, 2010 | 09:50 PM
LT1_Fireman's Avatar
Default help needed
Ok guys, I am working on the final touches for the mazda in my sig... I have a slight issue though. I want to know since in turns over, fires up, starts to idle then dies every time if that sounds like Vats to you all? It is all out of a 93 camaro, so its a flippin chip. I have no way to check it out and see if it was tuned out ,as well as the emmisions stuff, like I was told when I bought the setup. I have checked all of my work and its the only thing I can think of that it can be. Any ideas or input into the situation is welcome.
Thanks all.
Old Sep 22, 2010 | 09:55 PM
LSWHO's Avatar
I thought vats would keep it from starting at all. Never heard of it killing a running car.
Old Sep 22, 2010 | 10:07 PM
IDK thats what I thought too im at a loss this is the first lt1 swap Ive done... plenty of ls swaps tho and never had one do this
Old Sep 22, 2010 | 11:07 PM
defaultexistence's Avatar
fuel pressure? plug wire placement? ICM checked out?...
Old Sep 22, 2010 | 11:12 PM
tricked94camaro's Avatar
i thought so too. sounds like a fuel problem.
Old Sep 23, 2010 | 10:59 PM
the injectors are shuting off just as soon as it fires
Old Sep 23, 2010 | 11:34 PM
hows the fuel pressure? you hear the pump priming?
Old Sep 24, 2010 | 10:02 PM
44psi and yes its hot wired now
Old Sep 24, 2010 | 10:16 PM
lt1-xjs's Avatar
Is it throwing any codes ? It may have to do with being hot wired.
