Is this common on Pacesetter Longtubes? This is a pic into one of the primaries of my brand new Pacesetter LTs. It's like this on several of the primaries. These are very pronounced bumps, they are somewhat sharp too. Is this common, or is this a defect which constitutes returning them? I don't know enough to determine if this will hinder performance at all, although I'd think it would cause some turbulence in the airflow since it's immediately after the exhaust port, but I'm no expert. My first thought is to exchange them for a new set, but if this is normal for Pacesetter headers I don't want to trouble the vendor only to receive another set that has the same thing. Any thoughts? http://i36.photobucket.com/albums/e2...c/P1010859.jpg |
Mine didn't have that...normal? No clue, wouldn't think so. |
mine didn't have that either. i would worry about the random chance of one of those breaking off and somehow managing to get into the head. i do not think it would be unreasonable to exchange them for another set. |
Just looks like welding spatter it can't get into your heads the exhause flows out not in |
iirc exhaust reversion could cause one of those to end up in the head if it broke off |
I figured it was welding splatter, although that's some pretty gnarly splatter IMO. Would you guys run it or return it? |
Originally Posted by Birdie2000
(Post 13933477)
Mine had the same thing. I knocked them off with a chisel, most of them came off easily. |
just knock them off or grind them down with a dremel |
Small chisel and a hammer and they will easily knock off. |
© 2024 MH Sub I, LLC dba Internet Brands
