what cam should I get?
Old Jan 29, 2004 | 05:37 PM
SSC5R's Avatar
WARNING! Bad Seller Alert
Question what cam should I get?
I have a 94Z auto with a couple of parts laying around.
-52 TB, ram air box, edle shortys and cat back, 1.6 rockers, crank pulley, ported heads that flow 270cfm, and a hypertech program that is programed to my car but I've lost the programer box. What kind of power should I see at the wheels with the right cam. should I go solid or what do you guys think.
Old Jan 30, 2004 | 07:29 AM
License2Ill's Avatar
I'd go with the GM 847 cam. I've only heard good things about it. One dood is running 11's with it and slicks. Perfectly tuned it has cranked 400hp for more than one person and still retain streetability and that's at the wheels, man. It's not the usual hype cam, it takes no prisoners. And it's a GMPP.
Old Jan 30, 2004 | 01:02 PM
SSC5R's Avatar
thanks
Old Feb 1, 2004 | 04:10 PM
SSC5R's Avatar
with what I have listed above what kind of power would it make to the tires? Say I has the 306 cam.
Old Feb 12, 2004 | 09:12 PM
HOOZNXT's Avatar
go to www.combinationmotorsports.com they have quite a few custom ground XE CompCams. I've heard NOTHING but good things about them. Give'em a call, they know their stuff.
Old Feb 12, 2004 | 09:13 PM
HOOZNXT's Avatar
As a matter of fact here is the page that you need.
http://www.cmotorsports.com/engine/l...ft-design.html
Old Feb 12, 2004 | 10:53 PM
SSC5R's Avatar
Thanks for the info. I will call them tomarrow.
Old Feb 13, 2004 | 11:32 AM
94Formula/TA's Avatar
A good streetable cam with those mods would be there part number TN-230XL. And It gives a nice lopey idle.
Old Feb 13, 2004 | 12:14 PM
HOOZNXT's Avatar
I would say that cam is the most popular with the M6 guys. But since you've got an auto that cam is going to be way too big. With your auto you're going to want to go with a cam no bigger than the TN-224XL and that might even be a little much with out a torque converter. You can definately use that cam, but it's not going to be a monster off of the line without a torque conver. Just a little 2800 stall would do the job. If you don't have a stall or aren't planning on getting one I would go with the TN-218XL, still a good cam, bigger than the CC305 and since it has a 112 LSA it will give you the nice lope. I'm no cam expert, but I've got an auto and have emailed Seth at Combination a few times. So all of the info above is just me repeating what he has told me.
Old Feb 13, 2004 | 11:33 PM
SSC5R's Avatar
I'm pulling the auto out and putting in a T56. I'm switching to a AFR 227 head and a powerdyne supercharger with a 8lbs of bost, Arizona speed 58mm mono blade TB, LT headers, LT4 intake, 383 stroker + spray. Would like to go with a solid cam.
Old Feb 14, 2004 | 11:48 AM
SS MPSTR's Avatar
Get your heads flowed and call Seth to order a custom grind. Don't waste your time trying to find the optimum off the shelf grind. The extra cost is well worth it.
Old Feb 14, 2004 | 07:42 PM
SSC5R's Avatar
Thanks SS MPSTR
Old Feb 17, 2004 | 03:54 PM
Mike Frey's Avatar
Why? As good as hyd. roller cams have gotten, you must really enjoy adjusting valve lash.
Old Feb 18, 2004 | 12:42 PM
disco192's Avatar
Well a solid roller cam with good springs does allow for higher rpms and steeper ramps. If you dont mind adjusting the lash about every oil change.... who cares. It is a little more mainenence, but thats what separates the winners and the losers.
Old Feb 18, 2004 | 02:22 PM
SSC5R's Avatar
Thats right
