the "ROLLER"
Old Oct 31, 2010 | 11:08 PM
speedracer2536's Avatar
Originally Posted by robsquikz28
Are those proforms?[/QUOTE]
ya they are.. I've run them on all my engines.
Old Oct 31, 2010 | 11:23 PM
MattSapp95_T/A's Avatar
Looking good!! Keep it up!
Old Jan 24, 2011 | 05:18 PM
newest pics.. It moved for the first time in 3 years under its own power!!
Old Jan 24, 2011 | 06:54 PM
AChotrod's Avatar
Nice!! Congrats!!
Old Jan 24, 2011 | 09:45 PM
SoxXpupPeT's Avatar
looking good. i like how the rear tires are sitting in the wheel well. nasty!
Old Jan 24, 2011 | 10:11 PM
tricked94camaro's Avatar
i love these kind of threads!
Old Apr 26, 2011 | 10:12 AM
Pic after the first drive.
Then after about 5 miles or so of drive time and what not with the new setup i started to get a horrible backfiring condition.. Intake did not seal at all so i pulled the intake.. Then decided to pull the heads on a hunch.. well one piston came up just a bit higher than the others so i decided to just pull the motor again.. Turns out #6 was showing copper.. Damn machine shop didnt recondition my rods correctly.. Anywho to make a long story short i have a friend who works at hke and he gave me a bad *** deal on parts and labor for a forged 355.. so i decided to pull the trigger on it
So i took my heads to classic engine machine and turns out that they were not true.. Had em cleaned up and they came out pretty bad ***.. He re polished them and setup the valve springs and what not..
After that my motor came back a few weeks later
Then this past weekend there was a big push to get more done on it got new tires mounted, engine bay painted, side molding stripped, engine painted, All of the stuff swapped to the tubular kmember, also installed the rear lowering springs. Im hoping to have it all in next weekend. Maybe have it fired up..
Old Apr 26, 2011 | 10:13 AM
Just for ***** and giggles this was the day after i picked the car up.. I decided to celebrate..
Yes the third row is gone and the second row is folded into the floor..
As far as the plans go though.. It will be getting a 200 shot..
Old Apr 26, 2011 | 10:14 AM
Here is the new mod list as well..
mods are as follows:
stock crank cleaned up to help with any windage
acl bearings
scat forged rods
speedpro forged pistons
moly rings
cc306 cam
floo tech stage 3 ported heads 2.00/1.6 valves
arp headbolts
crane 10308 spring kit
1.6 nsa rockers
pacesetter long tubes
tsp offroady
flowtech cutout
dynomax bullet muffler dumped at the axle
hurst short shifter
competition clutch stage 5 clutch
walboro 255 fuel pump
pro kit, may swap to sportlines later
Nitrous
granetelli LCA
pa racing tubular kmember
(still in the works) 411 pcm swap
subframe connectors
csr electric waterpump
sjm linelock and abs delete
Deleted:
A/c
abs
cruise
rear seats
Lots little brackets and misc ****
Old Apr 26, 2011 | 11:24 AM
sempire's Avatar
What's involved in cruise delete? Does it save any weight or make any sense other then just getting rid of it?
Old Apr 26, 2011 | 11:37 AM
95mysticta's Avatar
Looks great man...
Old Apr 26, 2011 | 12:04 PM
  #32
I did it to save weight.. Plus i dont like to use cruise control.. All you do is unbolt the motor and unhook the cables
Old Apr 26, 2011 | 12:08 PM
  #33
robsquikz28's Avatar
looks good bro and it has 250 shot written all over it.
Old Apr 26, 2011 | 12:17 PM
  #34
litch2004's Avatar
Glad to see another afb member on the board. we need some more nice fbodys in this area.
Old Apr 26, 2011 | 12:25 PM
  #35
Tony Shepherd's Avatar
Cool project. Good job!
Old May 11, 2011 | 10:06 AM
  #36
well i finally got it all done.. Ran into a few issues with the intake seating right with my block zero decked but i got it figured out.. Should be in tonight..
Old May 11, 2011 | 10:37 AM
  #37
draggin97s10's Avatar
nice build man!
