Hitting rev limiter at WOT
Old Oct 10, 2010 | 06:36 PM
z28DC's Avatar
I know you guys keep telling me its the trans and im being stubborn however i just realized, If i go full throttle from a dead stop it doesn't do it, its only full throttle from a 30mph or under roll. Does that make any difference?
Old Oct 10, 2010 | 08:15 PM
95z28onjuice's Avatar
Ya thats because it skipping 2nd im sure and going to 3rd where at 30 its down shifting and missing the gear all together.
Or if your rear gears have been changed and the Ecm does not know there changed would do that as well. it would vounce 3 times then shift almost everytime if this was the problem. You speedo would be off. i did not see any of this listed
Old Oct 10, 2010 | 08:48 PM
z28DC's Avatar
Thats exactly to a T what it does. 3 times, Im going to take the cover off and look tomorrow, anyway i should know the difference from stockers?
Old Oct 19, 2010 | 09:03 PM
1Bad97WS-6's Avatar
Ya stock gears are 273s/323s.. Look at your door code GU2 is 273s and GU5 is 323s..
Old Oct 19, 2010 | 10:42 PM
94Aquaformula's Avatar
Mine is doing this I had it tuned for my 295\45\17s then I put my 275\45\17s back on...the taller tire was making it not shift right on WOT..and if you have a stall it can hit the limiter also..its called the "lt1 stall wall" hope this helps
