1.6 Rollers..
Old Oct 10, 2010 | 06:47 PM
defaultexistence's Avatar
Default 1.6 Rollers..
i know this has been milled over like 1,000 times but what are the facts regarding 1.6 SA RollerRocker use on stock springs? what do they do to the numbers in relation to the springs limits? As i under stand it the spec's on the cam are 205/207 duration @ 50*, .447/.459" lift, 117 LSA Stock and springs seated at 85lbs? with a 5700 redline ...Thinking of getting some SA roller rockers, if the stock springs will Technically be ok/within spec for now... aside from the obvious ,what do they actually do/change?
Old Oct 10, 2010 | 08:31 PM
BLK,97,T/A,M-6's Avatar
You will only gain .03 lift (I think) so its really not worth it. Your better off spending the money somewhere else. like gears.
Old Oct 10, 2010 | 08:54 PM
BlackBird87's Avatar
youre lift will be .477/490 and i believe it will add a lil bit to the duration. but i wouldnt run the stock springs
Old Oct 10, 2010 | 09:06 PM
for a DD I'm ok with my 3.23 gear ,i hear others regretting the 3.73 swap..need a stall...anyhow .. so the stock springs are good to what .500 ? i'm really not looking forward to changing the springs..i hear storys of stuck locks. just wana squeeze whats left outta the stock cam and add the benefits from a roller setup for now ... prob right tho...springs do have alot of miles to be monkeying with em'
Old Oct 10, 2010 | 09:28 PM
RamAir95TA's Avatar
Stock springs are only sufficient with the stock cam and stock ratio rockers. Change either one and you're looking at a valve spring upgrade. Many argue that you can run stock springs on 1.6 rockers, but it is NOT a wise idea.
Old Oct 10, 2010 | 10:25 PM
IronOutlaw's Avatar
Just get lt4 springs I think they're like 40 bucks. That's better than chancing dropping a valve isn't it?
Old Oct 10, 2010 | 10:46 PM
hitmanws6's Avatar
Should be right around a 10hp gain, as stated get the LT4 springs and call it a day
