New engine build! step inside for ?s 388 lt1
Old Oct 28, 2010 | 08:06 PM
Wicked94Z's Avatar
Originally Posted by LSWHO
Lower LSA, high stall. check.
Wait what?
This is UNREAL.
It has nothing to do with lobe separation, it has to do with about 5 different cam "specs" that you're ignoring...
Old Oct 28, 2010 | 08:10 PM
Wicked94Z's Avatar
Originally Posted by SPRAYED Z
HAA lswho must not be liked huh?
I can either go with that cam or I can go solid roller and get a larger cam. But how much of a power difference can I make going to solid?
HOws the cam that was chosen to me by LE?
The PCM and stock intake are a bigger limitation to this combo than the HR cam. The stock PCM and HR rpm limitations fit well together. Stock intake just ain't a great design for the rpm range you need to make power in with those limitations.
The LE cam looks ok, I'd like it more on a 108+2. It wouldn't hurt top end one bit, but will give you more midrange, which you could use with the modest compression.
Old Oct 28, 2010 | 08:50 PM
LSWHO's Avatar
deleted
Old Oct 28, 2010 | 08:58 PM
robsquikz28's Avatar
bbbwhwhwwwhhwhhaaaaaa this thread is getting awesome. But OP that cam you listed from LE is a very well specd cam. THe power level will be great and are you shifting at 7krpm or is that when you want the most power to be achieved. POwer levels are pretty much cut off at that rpm and the stock pcm is limited there too.
Old Oct 28, 2010 | 09:17 PM
speed_demon24's Avatar
Look at how narrow my tight LSA powerband is. I definitely need to widen it.
Old Oct 28, 2010 | 09:37 PM
Wicked94Z's Avatar
I've noticed that any thread Detective LSWHO posts in becomes epic.
Old Oct 28, 2010 | 09:41 PM
NO ****,lol. Hes mad his valve springs still arent on his heads
Old Oct 28, 2010 | 09:47 PM
Wicked94Z's Avatar
PROOF!!!!!!111
Old Oct 28, 2010 | 10:27 PM
SS RRR's Avatar
Village Troll
Originally Posted by Wicked94Z
PROOF!!!!!!111
If Captain Bad Info Police cannot win a technical debate, the good Captain will beat the **** out of with wordiness... Watch it!
Old Oct 29, 2010 | 01:01 PM
SPRAYED Z's Avatar
LOL he is really hated. SO guys hows my setup? New thread beginning
Old Oct 29, 2010 | 01:11 PM
quik95lt1's Avatar
wow another e dick competition brewing in here lol.........im all in favor of big cams but in your case becuase of that stock ecm 7000rpm thing your gonna have to take it easy........id say go with a low lsa to keep the range down but then again if we do that its not going to react well to the nitrous.....no point in all that overlap blowing nitrous out the exhaust...........i kinda like wicked's 246/258 108+4 cam.........i mean that still doesnt tell us alot about it but shooting from the hip its not bad......i may actually lower that duration a bit becuase i think its gonna go over that 7000 spot espically if you got some big *** heads on there like ur describing........maybe knck it down a few degrees on each side like 242/252 108+4........as for solid vs. hydraulic.......a correctly built solid will ahve the longevitiy and WILL make more power than a HR
dont get me wrong I am in NO way a nitrous professional........i know my way around NA motors well as well as FI but this should help ya out.......just remember bud this is ls1tech dont beleive everything u read......you seem like a smart guy you'll be able to distinguish between garbage and real results
Old Oct 29, 2010 | 01:42 PM
  #32
LSWHO's Avatar
deleted
Old Oct 29, 2010 | 01:46 PM
  #33
LSWHO's Avatar
deleted
Old Oct 29, 2010 | 03:56 PM
  #34
quik95lt1's Avatar
lmao somebody is gonna pop a blood vessel in here or something this is frickin hilarious
Old Oct 29, 2010 | 04:15 PM
  #35
deleted
Old Oct 29, 2010 | 04:30 PM
  #36
LSWHO's Avatar
deleted
Old Oct 29, 2010 | 05:40 PM
  #37
JasonShort's Avatar
Moderator
LSWHO, get ahold of yourself. Your actions are killing someone else's threads and is not fair to the OP. Give it a rest.
