radiator issue
Old Oct 27, 2010 | 10:46 PM
mattcossel29's Avatar
Default radiator issue
I am trying to see how I should run my radiator hoses due to an issue I have with my radiator.
The nipple seen in the picture below that is capped off with the black cap is broken off.. The hole has been sealed but I am seeing high temp issues.. I do not think it is an issue with the thermostat because the coolant is bubbling pretty good after it warms up.
I am unsure what this nipple that busted off is for.. I believe it is for the steam tube.
Oh this is a fresh motor..
The picture is just used for reference of the radiator.. Its a fourth gen radiator used in an unknown vehicle.. This is the best picture I could find that showed the nipple that I discussed in the first post.
Any information on this will be appreciated..
Thanks!
Old Oct 28, 2010 | 12:05 PM
jaycenk's Avatar
What are we looking at here? a small block chevy gen 1? with what heads? and what intake?
Old Oct 28, 2010 | 03:43 PM
Old Oct 28, 2010 | 03:49 PM
RamAir95TA's Avatar
That fitting is indeed for the steam tube. Not having it connected is muy bad. You can always have a fitting brazed into the radiator tank.
Old Oct 28, 2010 | 04:02 PM
Is there a way to run the steam tube into any other way? Such as putting a T hose that runs somewhere else?
Old Oct 28, 2010 | 04:08 PM
SS#502's Avatar
Maybe because it's a reverse cooling system it was designed for the internals of the radiator is different? Is this thing for Drag only cuz a cooling fan would help out a lot...
Old Oct 28, 2010 | 04:47 PM
shbox's Avatar
You could tee it into another hose, but it would need to be one that the flow is going to the radiator.
Old Oct 28, 2010 | 05:12 PM
Fantastic, thank you!
BTW, I appreciate your website so very much! It has helped me countless times on my rebuild and my 93/94 swap.. Thanks to you I even have a .pdf owners manual for my car.. Stored on my phone!
