Injectors and Vacume Question??
Old Nov 7, 2010 | 01:16 PM
jasonz28camaro's Avatar
Default Injectors and Vacume Question??
i have some sort of a vacuum issue with my 96 lt1. i think its vacuum because if im driving and stop my rpms will jump up and down 500 or so then drop down to 400 when i stop all the way then it will die or go back up to 750. i have ford 30lb injectors and they seam like they are not in all of the way, could that create a vacuum leak?
Old Nov 7, 2010 | 02:27 PM
LarsV8's Avatar
Are there little o rings between the injectors and manifold on yours?
Old Nov 7, 2010 | 08:57 PM
not sure what your saying... there are two, one for the fuel rails and one that seems like it should sit inside the manifold. my problem if it is a problem is that i can see the o-ring.
Old Nov 7, 2010 | 10:55 PM
RamAir95TA's Avatar
Did you get reprogramming for your 30# injectors, and have you monitored your IAC counts?
Old Nov 8, 2010 | 10:23 PM
sorry what are IAC counts? And yes it has been tuned for 30lbs.
