raptor shift light
Old Nov 7, 2010 | 03:27 PM
Torchie94's Avatar
Default raptor shift light
i just purchased a raptor **** light and im a little confused on where one of the wires goes.
in the instructions it says. connect the green wire of the shift light to the tach output lead of the vehicle or the switched side of the ignition coil(negative side)
so my question is.. which would be easier to get to to wire this in. and if the coil is easier to wire to. what side is the negative side, i have the 2 plug coil. (94 firebird)
thanks in advanced
Old Nov 7, 2010 | 03:55 PM
fergymoto's Avatar
The easiest place to get it from would be the tach wire that runs to the instrument cluster. Take off the passenger side kick panel and you will see some connectors, a blue one and a white one. You want pin D on the blue connector. It is a white wire and that is the tach feed.
Old Nov 7, 2010 | 04:16 PM
Torchie94's Avatar
thanks for the help man
Old Nov 7, 2010 | 04:18 PM
fergymoto's Avatar
No problem. I have a Raptor shift light too, love it.
