Fuel Pressure
Old Nov 8, 2010 | 02:59 PM
2fast4u1989's Avatar
Default Fuel Pressure
i have had some slight hesitation at low rpms latley. did a fuel pressure test, hooked guage to the shrader valve and im reading 40psi when key on engine off. 34 psi with engine on idling. 45 psi with engine on and vacum pulled off of the regulator. and heres the kicker. reading 33 psi when vacum is hooked to the regulator and reving motor. does this sound like fuel pump may be quiting on me soon?
