FPR problem maybe? something else? Please help.
I checked the fuel filter, it's clean. I don't have a fuel pressure guage to fit the fitting. I guess that's my next step, but it rides beautiful at cruising speeds or all the way up to 60-70% throttle. I'm thinking it's a lean condition or ???not sure what else since the spark is good and every other data log field looks good.
What happens when FPR starts going bad? Any other ideas. IAC maybe? I would really appreciate it.
What next?
I don't have access to 100 octane at the moment, but I'll be sure to try that soon.
This is how it started: I was getting a misfire and the car was running like **** and of course knocking when under a load. BLM on right side went way up. It was a plug wire, so I swapped it out. I actually swapped out all of them on the right side. BLM came back down and motor was strong and back to normal, except I still can't get this knock to go away at high throttle.
I sent Solomon an email with a datalog, so I'm hoping he will have suggestions, but I'm still open to any other thoughts.
On a brighter note: my wheels and tires came in today. OEWheels C5 DD 18x10.5 with BFG KDW 295/35/18. A huge upgrade from my 225/60/16s. I'm lovin them, but would enjoy it much better if I could get this solved.
The LT4 module can be good for you if you have headers or valvetrain mods.
I replaced the opti because it failed. I replaced the FPR, and fuel pressure is more consistent. I installed an LT4 knock sensor. Waiting on a new fuel pump, 255 Walbro.
The opti seemed to help or reduce the knock at least, but it's still there. The LT4 knock module didn't seem to change anything. It seems just as sensative as before.
I haven't tried high octane fuel yet, so I guess that's my next step but I honestly don't know where I would get any. I'll ask around. I run 93 octane and have been since I've had the car.
I need to also try adjusting the knock sensor and back it out 1/4 or 1/2 turn if it's too tight.
The thing that bothers me about this is that it all started when my plug wire(s) was misfiring, because the A/C pulley carved into the wire. Being my only vehicle, I drove it to work 2 or 3 days with the misfire, and after replacing the wires, the knock never went away. Could I have damaged something else by driving with a misfire?
One more thing that seems odd: if I'm cruising at 45mph in 4th gear and stomp the gas, I get knock as it's in transition to downshift, then when it drops gears, the knock seems to be less. If I drop it down in 2nd gear manually at 35-45mph, then stomp on the gas, barely any knock, sometimes none. Does this mean anything to anyone?
It could actually be engine knock.....from bad parts...
If your knocking isn't getting any better after going to the LT4 knock module and you're still throwing codes, it may be a good idea to pull your valve covers and check your valvetrain.
