Help with wiper arms
Old Nov 15, 2010 | 05:47 PM
TheTransporter69's Avatar
Default Help with wiper arms
Hey guys, I'm trying to get my wiper arms off my 94 t/a to switch to the ls1 style arms. My question is how to get them off, I popped the cover up exposing the 13mm nut. I then took the nut off, the arms still feel like they are solidly attached though, and i don't want to break anything. Is there more safety pins or something? Or is it just stuck from being a 16 year old car?
Old Nov 15, 2010 | 05:49 PM
RamAir95TA's Avatar
They are press-fit on. Use a puller if you have to. Resist the urge to pry on them with a screwdriver because you WILL break the glass.
Old Nov 15, 2010 | 05:54 PM
i don't know if i have a puller around here i don't think I do. If they are press fitted on do i need to do something special to get the new ones on or do they just set on and bolt up?
Old Nov 15, 2010 | 05:55 PM
RamAir95TA's Avatar
No they just bolt on. You'll see the seat for them is tapered and splined. That's why they are hesitant to come off. With enough wiggling they will eventually come off. If they still don't, resort to the 2-jaw puller.
Old Nov 15, 2010 | 05:57 PM
ok will do thanks a lot Joe.
flame's Avatar
A little bit of heat on the arm right around the stud works like a charm. Even a little soldering torch is enough.
Old Nov 15, 2010 | 05:58 PM
ill keep that in mind too ^ Thanks.
Old Nov 15, 2010 | 06:22 PM
DisturbedTA's Avatar
i just used a flat head and pryed it up. but ive don it a lot of times still scary lol
