Question: Underdrive pulley
Old Nov 17, 2010 | 12:56 AM
Camaro_ZL2's Avatar
Default Question: Underdrive pulley
I recently bought and underdrive pulley from a member here he said he pulled this off a 93 z28 yet it bolts on but sticks out a little too much meaning its not going to work why is this? and they did this at the shop i was watching as they tried to sort the problem they even tried flipping it and no go it hits the block.....then we tried to see if it fit my buddies tpi vette and nope..........so why did this fit a 93 and not my 95 z28/b4c?
Old Nov 17, 2010 | 07:18 AM
camar0corey's Avatar
Is it a piggyback pulley? If so you are supposed to install the stock balancer back on top of the underdrive pulley. Then the bolts should be the proper length. If they are still just a little too long at that point shim the bolts with washers, I had to do this on one of the pulleys I ordered years ago, had to use like three washers per bolt that the pulley had shipped with.
Old Nov 17, 2010 | 01:08 PM
Camaro_ZL2's Avatar
No its not piggy back....and i dunno this is just so frustrating i know this part belongs to my car i dont know why i sticks out too much where the belt wont sit right
Old Nov 17, 2010 | 01:13 PM
*CAMARO*'s Avatar
Just put the stock pulley back on. You will never tell the difference!
Old Nov 17, 2010 | 01:35 PM
Camaro_ZL2's Avatar
lol nah man i actually wanna do this even it if doesnt do much do i need longer bolts?
Old Nov 17, 2010 | 02:01 PM
*CAMARO*'s Avatar
I don't see how longer bolts would help. If the pulley doesn't line up with the other accessory pullies it's probably the wrong pulley for your car. Make sure it is tight against the hub.
I know I tried using the hub from a b body LT1 once and it made the pulley stick out too far past the other pulleys. If it doesn't line up and you've already tried flipping it then I'd say it's the wrong pulley.
Old Nov 17, 2010 | 03:07 PM
Pictures?
Old Nov 17, 2010 | 03:45 PM
Camaro_ZL2's Avatar
ill take some this is the pulley
Old Nov 17, 2010 | 04:08 PM
tricked94camaro's Avatar
theres a variety of different things from the 93 and 94-97. the pulley is probably one of them.
Old Nov 17, 2010 | 04:11 PM
Camaro_ZL2's Avatar
yeah but then why do they sell the pulley and it say 93-97 just a question
Old Nov 17, 2010 | 11:21 PM
then maybe its not one of them... idk.... just a suggestion!
Old Nov 18, 2010 | 01:23 AM
Camaro_ZL2's Avatar
thats what i thought but it has the same measurements and everything
