LT1 Questions
1. What kinda cam would be good for streetable power (midrange) and keep decent drivability and good gas mileage.
2. With respect to roller rockers...does it make much of a difference going from 3/8 stud to 7/16 and for a street motor is it really beneficial to go non self aligning.
3. Would porting the heads do much for fuel economy...good or bad?
4. What would be a good compression ratio? I'll be running premium gas.
2.) A 7/16" stud is far more rigid than their 3/8" counterparts. Non self-aligning rockers are far more stable at higher RPMs than self-aligning.
3.) The point in porting heads is to increase runner volume and velocity in an attempt to put more air/fuel mixture into the combustion chambers, increasing fuel consumption. A big part of fuel economy also has to do with the tune.
4.) Static compression ratio has nothing to do with whether or not you can run pump gas. There are guys (like myself) running closer to 13:1 running on pump gas without a problem. It is far more dependent on the cam choice and your overall dynamic compression ratio.
Its all up to you..........................but it is a good excuse to make it faster.
