Oxygen sensor qiestions
Old Nov 21, 2010 | 04:06 PM
linkziz's Avatar
Default Oxygen sensor qiestions
Hello everyone i have a 95 camaro with a 93 lt1 setup in it. Im just wondering if anyone knows which o2 sensor i should use to replace the single wire ones. I have long tube headers so the sensors dont get hot enough to work properly.I was just looking for a GM, ac delco, or denso part number for heated sensors.
Old Nov 21, 2010 | 04:53 PM
Fazz73jr's Avatar
Are you still using the 95 pcm and wire harness? If so just get some AC delco o2's for the 95' camaro. If your using the 93 pcm and harness search here for the 93 heated o2 conversion.
