What headers are these???!!!
Old Nov 28, 2010 | 11:45 PM
pboxfun's Avatar
Arrow What headers are these???!!!
I was told they were jet hot coated long tube headers. Are they?? and what brand of headers are they??
Thanks for all your help!!
Old Nov 29, 2010 | 12:06 AM
speedracer2536's Avatar
they look like jet hot or hooker's
Old Nov 29, 2010 | 12:42 AM
RamAir95TA's Avatar
They are Jet Hots/Hookers. I ran them for awhile. Nice headers, but hated the 3-bolt collectors.
Old Nov 29, 2010 | 10:26 AM
pboxfun's Avatar
Why did you hate the 3-bolt collectors? Also what ORY is the best to use with these?
Old Nov 29, 2010 | 12:59 PM
RamAir95TA's Avatar
3 bolt collectors leak, are a PITA to line up, and reduce ground clearance. Slip fits are far more forgiving.
The best y-pipe for them is the y-pipe that comes with them. You should still be able to order it.
Old Nov 29, 2010 | 01:27 PM
1badzee's Avatar
That flange looks a bit different than that on my Jethots.. Either way, they look identical minus that. I like the headers. The 3 bolt flange kind of sucks, but I have exceptionally good ground clearance. Slip fit ftw though
Old Nov 29, 2010 | 01:37 PM
gunter96ws6's Avatar
hookers for sure
Old Nov 29, 2010 | 01:56 PM
guppymech's Avatar
Jet hot have O2 sensor bungs on inside of collector. Hooker have the O2 sensor bungs on the outside of the collectors.
Old Nov 29, 2010 | 04:17 PM
robsquikz28's Avatar
NOt hookers but possibly knock offs. The driver side header 1 and 3 tubes where they merge together should make a complete looking flange on the head. That gap is far to large to make a complete flange. Secondly all hookers that I have ever had/installed or seen for the lt1 cars use 02 sensor positioning on the outside of the headers. As in the o2s face the outside of the car not the inside, like yours may be.
Old Nov 30, 2010 | 10:03 AM
pboxfun's Avatar
You think their knock offs??? Does anyone know why the last header isn't connected with the other flanges? Anyone have headers that look like this?
Old Nov 30, 2010 | 10:09 AM
pboxfun's Avatar
I was just looking at the pictures and saw that it looks like only the drivers header flange is cut but not the other passenger side header. Any ideas???
Old Nov 30, 2010 | 10:12 AM
its so you can fit it around the steering shaft.. it makes it easier to get them in.. hookers come like that
that primary slides out or off the actual header
Old Dec 3, 2010 | 12:14 PM
enjoi355's Avatar
yup, those are hooker/jet hot headers, just like others have mentioned, they are probably not genuine hookers, but dont worry, cause if theyre jet hots they really good anyways.
that #1 primary is made to slip in and out
