Is it Possible to Get 12s with a 3200 Stall???
Old Dec 1, 2010 | 05:23 PM
pboxfun's Avatar
Question Is it Possible to Get 12s with a 3200 Stall???
Just as the title reads. I have a friend telling me I can get 12s unless I put a higher stall in there. My mods are in the sig. What do you think?
Thanks
Old Dec 1, 2010 | 05:55 PM
robsquikz28's Avatar
With those mods Im surprised you havent ran 12s already? If those are your mods with a 3200 stall already. Why would you be asking that ? again about a stall that have.
But in reality that car should trap mid 12s all day with that setup and possibly even low 12s depending on wt/ driver and 60ft.
Old Dec 1, 2010 | 05:58 PM
RamAir95TA's Avatar
Have you even ran the car as-is yet?
Old Dec 1, 2010 | 06:04 PM
LSWHO's Avatar
I did 12.73 in 1700' DA hotlapped and spinning with a 3200 performabuilt stall with less mods than you.
Old Dec 1, 2010 | 06:11 PM
duh's Avatar
duh
been to the 12's with a 2800 converter.....just sayin....
RamAir95TA's Avatar
I ran 12.9s all day with the stock heads, cam, and converter back in the day.
Old Dec 1, 2010 | 06:30 PM
LSWHO's Avatar
Care to share how? I guess if it was newer, in good/great weather, and lightweight it's possible. But not common or normal.
Old Dec 1, 2010 | 09:35 PM
pboxfun's Avatar
The best I've done so far with the car was a 13.2 on a hot day during the summer with the mods in my sig and shifting at 6100 rpm. I'm hoping to get 12s this time around. Only reason I asked was because that's what someone told me
Old Dec 1, 2010 | 09:49 PM
CamaroRacing12's Avatar
have u ever gotten the car tuned? if not i wouldnt make another pass without it getting tuned. also i would double check it mechanically, plugs/wires, etc
Old Dec 1, 2010 | 09:55 PM
pboxfun's Avatar
new plugs NGK and it was tuned by MADZ28
Old Dec 1, 2010 | 10:01 PM
Lawhead's Avatar
12's no problem
Old Dec 1, 2010 | 10:04 PM
pboxfun's Avatar
Hopefully my car was just being a retard that day!
Old Dec 1, 2010 | 10:08 PM
what did ur whole timeslip look like?
Old Dec 1, 2010 | 10:17 PM
henry172's Avatar
You must have wheel spin slowing your time down or something is wrong.
Old Dec 1, 2010 | 10:18 PM
pboxfun's Avatar
R/T .295
60' 1.873
330 5.454
1/8 8.454
MPH 81.78
1000 11.043
1/4 13.221
MPH 103.75
I even have the datalog from that run as well if anyone is interested in looking at it
Old Dec 1, 2010 | 10:19 PM
tricked94camaro's Avatar
thats what i was thinking
pboxfun's Avatar
I was using hoosier DRs
Old Dec 1, 2010 | 10:22 PM
SoxXpupPeT's Avatar
yeah theres something amiss there.. your car shouldnt have any problems trapping 12's.... were your running bicycle tires or something ? haha
Edit: Didnt see your newest post... your 60' is pretty good.. your trap speed isnt bad either.. somethings wrong tho to cause low 13's
Old Dec 1, 2010 | 10:36 PM
pboxfun's Avatar
Well here is the datalog if anyone wants to see if they can find anything wrong. I was using freescan.
http://www.qfpost.com/download.do?ge...358cd930294c85
Old Dec 1, 2010 | 10:44 PM
lt1-xjs's Avatar
You should run like 12.0x if not better. Something isn't right and I would raise the shift points to 6400 rpm for a start.
