EGR valve
Old Dec 8, 2010 | 07:07 PM
nascarnate326's Avatar
Man, thank god we dont have to deal with that crap in Michigan.
Old Dec 9, 2010 | 10:07 AM
94T/A5.7LT1's Avatar
I'm going to just get my catylic converter replaced and see if that helps or not.
Old Dec 13, 2010 | 04:02 PM
Go the catalytic converter changed Friday and I failed the emissions again today. I'm running out of ideas here on why it's putting out too much NOx. Anyone?
Old Dec 13, 2010 | 06:02 PM
flame's Avatar
You did get a three way catalytic put on right? When you changed the EGR valve did you get the one for an automatic trans because there is a difference. Does the car have headers?
Things that affect Nox : running lean, ignition timing too high, high combustion chamber temps, carbon in combustion chambers,
Old Dec 23, 2010 | 02:18 PM
ChandlerMotorsports's Avatar
Sounds like it definitely could be fuel. Otherwise ICM is a possibility, with an easy test at autozone (test it 6-9 times to heat it up). If you get low resolution codes, its your opti. Thanks for thinking of us.
