Radiator Install
Old Dec 4, 2010 | 10:29 AM
ClayBonics's Avatar
Default Radiator Install
Did a search really did not come up with anything. Replacing the radiator in my '96 Ram Air. Any tips, tricks, recommendations, anything I should watch out for. How much time needed in general? Thanks for the help.
Old Dec 4, 2010 | 10:35 AM
Puck's Avatar
Very simple and straight forward removal and install.
While you have everything out be sure to clean the low coolant sensor - it commonly gets dirty and gummed up which turns on a false low coolant light.
Old Dec 4, 2010 | 10:46 AM
ClayBonics's Avatar
I hear ya on the coolant sensor. Thats for the reply
Old Dec 4, 2010 | 12:10 PM
I8ASaleen's Avatar
Simple. Take off the upper radiator airflow dam, remove the hoses, push the intake elbow donkey dong out of the way, remove radiator.
Old Dec 4, 2010 | 01:07 PM
ClayBonics's Avatar
Cool, I just wanted to make sure there were no suprises
Old Dec 4, 2010 | 02:53 PM
LSWHO's Avatar
Be prepared to buy new coolant hoses. They tend to break when moved around. You may not have that problem, but it's a definite possibility.
Old Dec 4, 2010 | 03:35 PM
trilkb's Avatar
I wouldnt listen to any of these guys....unless you want coolant all over your garage floor
step 1 - Drain radiator - pet **** on bottom passenger side, can be a little stubborn to get loose, i went for accuracy instead of speed so i never took the valve all the way loose, but i got alot of coolant where i wanted it to be lol.
step 2 - follow what these guys said, be gentle with your tranny cooler lines too, dont want to mess those up. and be prepared for more coolant to come out of the lower hoses.
The rad fans come out pretty easy as well, Take off the upper radiator support, not sure on a ram air car but it might be connected with your lower airbox?. Get under the car, and push up on then, then manuver them towards the back of the car and they should slide out with some finess. Your AC condensor also sits in some brackets on the radiator so befor you start yanking make sure you take it out of its holding tabs.
Time wise, Give yourself probably 4 hours, you can probably do it all in under 2, but why rush it. Plus you gotta deal with bleeding the system out.
Old Dec 4, 2010 | 03:44 PM
RamAir95TA's Avatar
Here's my best shot at it:
If your radiator hoses have never been off, invest in a set of coolant hose picks. They are invaluable in removing old hoses without damaging them or the fittings. Not to mention they come in handy for TONS of other things too.
Disconnect battery.
Drain radiator via the petcock on the bottom passenger side of the radiator.
Disconnect oil cooler bypass hose from the bottom driver side of the radiator.
Remove airbox (four thumb screws, one bolt under filter) and disconnect from the MAF. Don't forget to disconnect the IAT.
Disconnect as many hoses as you can get to.
Remove fans. Unplug each motor and set the harness off to the side. Push UP on the entire fan assembly to disengage it from the four tabs that hold it in. It will take some finagling, but rotate it down and out.
Remove the transmission cooler lines, both feed and return. One will need a line wrench, the other just uses a slip-fit clamp.
Remove upper radiator support (3 bolts).
Remove radiator.
Old Dec 4, 2010 | 05:22 PM
speed_demon24's Avatar
No...
Old Dec 4, 2010 | 05:34 PM
LSWHO's Avatar
Originally Posted by speed_demon24
No...
Damn, you're right. Coolant hoses last 4 lifetimes. No need to ever think of replacing them in a 15 year old car.
Old Dec 4, 2010 | 05:37 PM
LSWHO's Avatar
Disconnect battery.
open/remove radiator fill cap
Remove radiator.
Added in a step to make draining quicker and so that the next step doesn't result in as much spillage if done in rapid succession.
Old Dec 4, 2010 | 09:43 PM
trilkb's Avatar
lol im glad my ******* comment got everyone in the mood to nit-pick
Old Dec 4, 2010 | 11:59 PM
SS RRR's Avatar
Village Troll
Mine are original and have been moved around plenty of times. Tell you what, I'll let you move my hose around to see if it breaks. Deal?
Old Dec 5, 2010 | 01:25 AM
LSWHO's Avatar
You guys are ridiculous. I feel like I'm in third grade talking to you.
Old Dec 5, 2010 | 01:35 AM
SS RRR's Avatar
Village Troll
C'mon baby bite my wire...
Old Dec 5, 2010 | 02:44 AM
If you need help looking for valvespring install write-ups all you have to do is ask...
Old Dec 5, 2010 | 02:15 PM
LSWHO's Avatar
Still waiting for you to prove me wrong on what i said. It's ok, I know you can't.
