uprgraded suspension question
Subframe connectors for weight transfer
panhard bar if youre lowered/wider tires to center the rear end
lower control arms and torque arm for traction
A-arms up front for added rigidity and weight reduction
K-Member for weight reduction and more elbow room in the engine bay
Sway bars, shocks, springs...
lots of different options in each category depending upon your build...
First thing....
Buy some LCA relocation brackets this will correct the stock geometry issue in these cars
Next Buy a Torque Arm Relocation Bracket again to allow you to move the torque arm to adjust instant center
Next I'd say some Tubular LCA's and then some adjustable rear shocks and drag bags
and if you got room in the budget a set of subframe connectors will help once the car starts really hooking........however the rear end will probably commit suicide long before this anyway lol.....
I would also purchase some subframes, that is a must in my opinion. Also take a look at torque arms for your setup.
Did I mention shocks?
Even though KYB AGX shocks are supposedly only "okay" shocks, the difference in handling was very noticeable, in fact, it may be one of the most noticeable things you can do to a F-body. The stock DeCarbons apparently aren't very good.
Koni shocks are supposedly the best, but I'm just going to go with Bilstein on my current LS1.
again, it all really boils down to what you want out of the car.
First thing....
Thanks
Matt
My old setup I was running Eibach Pro springs which gave a 1.3" drop front to back. My LCA's instead of being "somewhat" horizontal as they were in stock trim were now angle upward toward the rear wheels.
I imagine the ideal is to have your LCA's horizontal when you car is at full launch - as in, wheels have hooked, weight has been transferred, and your rear end basically hitting the floor (shocks & springs are as compressed as they can get). Correct me if I'm wrong here. Or do you want those LCA's to face at a downward angle towards the rear wheels?
