Fuel Rail Leaking.... HELP!!!
Old Dec 22, 2010 | 12:47 AM
SpeedFreak123's Avatar
The o ring goes on the end of the hose? And bend what back square?
Old Dec 22, 2010 | 12:53 AM
airfix's Avatar
Originally Posted by My95Z
I can't say for sure, but I do think injector o-rings will fit. I just bought a multi pack at AZ so I can't say for sure.
You aren't missing a bracket, its the rusted thing below the bolt that holds your rail on in your pic. They goes on sideways (4 of them) and hold the tubes to the rails. Just drain the tube of gas and remove the brackets with a torx head. Bend them back to square and reinstall.
I'm sorry but wtf are you talking about? Maybe I'm missing something but thats confusing.
Old Dec 22, 2010 | 11:41 PM
My95Z's Avatar
We are talking about the crossover tube on the fuel rails here, right? I'm starting to think I'm thinking of something else here too
You can take apart the fuel rails and tubes, it separates into 4 pieces. Two rails and two tubes. The brackets that hold them t/g and keep everything square (so the o-rings seal) can get bent when the assembly is forced.
Old Dec 22, 2010 | 11:43 PM
airfix's Avatar
Ahhh, ok sorry my bad. I wasn't aware that you could take them apart. All your posts make sense now lol.
Old Dec 23, 2010 | 12:32 AM
Got it back togeather , no leak. But it has a bad misfire. any ideas? Could the rockers being adjusted wrong cause a mis?
Old Dec 23, 2010 | 12:48 PM
My95Z's Avatar
If they are too tight, then yes it could. You would also notice it wouldn't idle very good and would be very down on power, not like a random misfire.
Old Dec 23, 2010 | 01:05 PM
Well the car doesnt idle very good, BUT the code says "Random Misfire"
