Old May 18, 2016, 06:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
Print Wikipost
how to remove 02 sensors on lt1?
Old Dec 27, 2010 | 11:08 AM
2fast4u1989's Avatar
Default how to remove 02 sensors on lt1?
hey guys i have 95 lt1, single cat car. i have only 2 o2 sensors. are they easy to do? my car is loosing gas mileage and performence is worse, and passenger side manifold glows even under normal driving. i did plugs/wires. so i think maybe its time for o2 sensors. and help or tips is greatly appreciated.
Old Dec 27, 2010 | 11:43 AM
SlowestTransAm's Avatar
Fairly easy.
As you said single cat LT1's only have 2 02's, one left one right.
You can buy a 02 socket wrench at Advance Auto or whatever your local auto store is for $5-$10
http://shop.advanceautoparts.com/web..._T|GRP2083____
Just unplug the clip from each sensor, wrench them off and replace. Maybe a PITA if they haven't been changed in a while and are rusted on there pretty good.
Old Dec 27, 2010 | 11:48 AM
Im new to some of this stuff, sorry if this is a dumb question, people talk of 2,3,4, and 5 wires. what are the difference? and what wire are our o2 sensors
Old Dec 27, 2010 | 11:49 AM
curacaoz28's Avatar
did it when car is cold with the help of WD40 and a pipewrench
Old Dec 27, 2010 | 11:52 AM
Not sure what they mean by that...
Unless you buy a universal 02 sensor that you have to wire into the connector (don't recommend) it's purely plug and go. Wires come attached and wired.
Should take you about 5-10 minutes to do. If you can do the plugs and wires this should be cake walk.
Old Dec 27, 2010 | 12:06 PM
ok im looking at the ntk o2 sensors. i dont want to pay for the aldelcos.
Old Dec 27, 2010 | 12:09 PM
RamAir95TA's Avatar
NGKs are hands down the WORST O2s you can buy. They have AWFUL reliability and a proven failure record. Do yourself a favor and pay for the AC Delcos, or else there's a good chance you're going to be buying them again in a few months.
Old Dec 27, 2010 | 12:13 PM
damn i was thinking that they were good that sucks. are bosch good
Old Dec 27, 2010 | 12:18 PM
I think Bosch have similar reviews...I've only done AC Delco's personally.
I believe the Pep Boys around here will put a warranty on their 02's...so if you burn them up they will replace them.
Old Dec 27, 2010 | 12:21 PM
RamAir95TA's Avatar
Nope. They are just as bad, if not worse. You can use them, but at a risk. Just do a Google search and you'll see what I'm talking about. Even though they are warrantied, who wants to have to go back under the car in 3 months, take them out, bring them back, and put the same shitty O2s right back in?
Delco should be the only substitute.
Old Dec 27, 2010 | 12:25 PM
k i will prob do acdelco then. quick quetion, when looking at the pic of the ntk sensor, why do they look alot different from stock o2 sensors. heres a link to summit for it check it out. http://www.summitracing.com/parts/NGK-21006/?rtype=10
Old Dec 27, 2010 | 12:27 PM
RamAir95TA's Avatar
Because they suck. Disregard everything about them.
Old Dec 27, 2010 | 12:28 PM
That looks like a normal LT1 connector to me...
Correct me if I'm wrong but I think the only other connector type for these cares is the rectangular/square one for the LS1's...
Old Dec 27, 2010 | 12:30 PM
RamAir95TA's Avatar
Rear O2s on OBDII cars use the square four-pin connectors.
Old Dec 27, 2010 | 12:35 PM
so are they the wrong sensor all together lol
Old Dec 27, 2010 | 12:48 PM
RamAir95TA's Avatar
AC Delco 19178930.
/thread
Old Dec 27, 2010 | 12:50 PM
TheTransporter69's Avatar
Those numbers you are referring to are probably the plug wires. Their number come form which cylinder they are hooked up too.
Old Dec 27, 2010 | 12:55 PM
RamAir95TA's Avatar
Sounds more like he's talking about the number of wires per O2 sensor...
Old Dec 27, 2010 | 01:26 PM
AChotrod's Avatar
Old Dec 27, 2010 | 02:36 PM
MasterTomos's Avatar
Yeah, steer clear of Bosch's. My buddy has gone through 3 in one year
Experts I've talked to have always reccomended AcDelco's. I've also been told that Denso's are good if you dont want to spend the money on the Delcos. I know a few people that have had great luck with the Denso's so those may be an alternative to look into.
