LT1 No Start Question
Old Dec 29, 2010 | 12:21 PM
Next level's Avatar
Default LT1 No Start Question
I have been bashing my head against the wall long enough.
I have no fuel pulse sometimes and no spark the other. I have never had both at the same time since i put in my new setup. I have gone through 3 optis, 2 ICM and 2 Coils all brand new and those are not the issues. I have also gone through 2 different computers same result.
Before i rip out everything and burn the wiring in my car and go carb'd. Is there anything else and anyone on here can suggest.
I have a new TH400 swap to it too. I feel there is something to do with wiring to that but i have no idea at this point. I have tried Speed Inc not much help there and same result with FLP. Its before very frustrating and about ready to throw in the towel.
Old Dec 29, 2010 | 01:30 PM
96azz28's Avatar
Thumbs down
it could be bad spark plugs
also i had a problem when my car wouldnt start at all and it ended up being that the intake wasnt in all the way. lol
Old Dec 29, 2010 | 01:38 PM
Fazz73jr's Avatar
Vats system?
Old Dec 29, 2010 | 01:44 PM
Next level's Avatar
plugs are new ngk
no vats on the car
Old Dec 29, 2010 | 02:25 PM
Next level's Avatar
You have to wire the park / neutral safety switch into the wire that goes to the lower clutch position sensor. For 4L60E conversions you will have to tap into the existing park/neutral wire.
i didnt do this, would this create my problem ?
Old Dec 29, 2010 | 10:17 PM
robsquikz28's Avatar
If vats is gone and your using a th400 you dont need to use the p/n switch at all. DId you eliminate the keyed vats as well and use a resistor?
Old Dec 30, 2010 | 10:54 AM
Next level's Avatar
am i suppose to ???
and how would i do that ?
Old Dec 30, 2010 | 11:58 AM
djjab57's Avatar
Ignition switch going out
Old Dec 30, 2010 | 09:26 PM
what year is the car?
Old Dec 30, 2010 | 11:02 PM
Next level's Avatar
would tha cause my issue ?
and the car is a 94.
Old Dec 30, 2010 | 11:09 PM
l 95 Trans Am l's Avatar
I had a similar no spark issue and it was my Optispark connector.
Old Dec 30, 2010 | 11:20 PM
red93z28lt1's Avatar
also I hate to say check all plug wire connections possible melted wires? grounding arc?
Old Dec 31, 2010 | 08:51 AM
djjab57's Avatar
Originally Posted by Next level
would That cause my issue ?
Yes, and its easy to replace. 1st look at it and see if it has burn marks like its arcing. The piece is white so easy to see burn marks
Old Dec 31, 2010 | 09:05 AM
http://shbox.com/1/vats_bypass.jpg
