Fast idle problem
Old Jan 1, 2011 | 01:38 PM
LT4TransAmSAN's Avatar
Default Fast idle problem
I have a 97 Trans Am with an LT4. My problem is when I drive up to a stop, the idle is at about 2500 RPM. Once I come to a complete stop it starts idling down to normal. If I push in the clutch and coast up to the stop it still won't idle down until I'm stopped. I have no vacuum leaks that I can find. Code reader does not show any codes. I did notice that the rubber elbow on the PVC sucks in some and may be resticting flow.
Old Jan 1, 2011 | 01:55 PM
RamAir95TA's Avatar
Vacuum leak or bad/stuck/dirty IAC. Monitor your IAC counts if possible.
Old Jan 1, 2011 | 07:07 PM
Default Thanks Joe
I checked the IAC with and ohm meter and got 50 ohms each side. That does not mean its not stuck thou. I forgot to mention, this started after I put in a new clutch. ??? Car sat for 3 months.
Old Jan 1, 2011 | 07:21 PM
Puck's Avatar
You need to datalog the car and monitor the actual IAC counts. If the IAC counts goe to fully closed and the idle is still high then you have a vacuum leak.
Old Jan 1, 2011 | 07:25 PM
DisturbedTA's Avatar
my ta does this sometimes too
