how long does it take to heat up??
When you start the motor cold, all of the water vapor that has condensed in the crankcase needs to be purged by the PCV system. Additionally, when it's not fully warmed up, any blow-by vapor quickly condenses when it hits the cold oil, and emulsifies into the oil, creating acids and other crap. This is more of an issue in cold climates though, and those cars with higher miles are more susceptible to such buildup. Letting it idle isn't the best idea either, because it still takes far longer to get the oil to proper temps as opposed to starting it and driving conservatively for the first 5 minutes or so.
Some people care about this, some people don't. If you've got a new(er) motor it's less of an issue, especially if you regularly change your oil.
Maybe I worded my original post wrong, so sue me.
I have no scientific knowledge to back this up, but obsessing over how to properly "warm up" an engine isn't worth the hassle. If you take it easy, and change the oil on a regular basis, you'll be fine.
And in regards to the thread coolant up to temp doesn't = oil and internals that are up to temp. My coolant is at 160+ in 1-2 minutes but the oil still takes 10-15 to get up to temp.
-Hey I'm totally open to people giving me ideas on how I could be ruining my cars and not even know it. Hell when I first got my '97Z I used to run the heater on 100% of the time because it kept the car from ever going above 180* and I thought that was a GOOD thing...
