idle problem
What color is the smoke?
Do you have a CEL on?
Have you scanned it yet?
Is the coolant level ok?
What brand opti?
How many miles on bottom end?, Top End? Opti?
What rpm is will it idle at?
no not yet i dont have a obd1 scanner
coolant level is fine
opti was bought on ebay, chandler motorsports 3 years ago
1200 on the bottom end
idles at 1200 then drops to like 200 barely idles, i have to give it gas to keep it running, sounds like its braking up and it back fires.
Sorry I can't be of better help!
im moving back to tampa fl next week so i have to get this car running, due to the cold i havent messed with it since dec lol
the blue smoke is not a good sign.. but black is fuel so its getting gas just not lighting it... pull a couple of the easiest plugs and check them too... From experience your problem comes from the opti...
i also tried to check the codes with a paper clip and it wasnt flashing anything. not sure if it makes a difference but the car was off when i tried to check the codes.
http://www.youtube.com/watch?v=_3CzHCfz-9A
clip only workes on 93 94 and possible but unlikely on 95... thats the year they were upgrading to obdII most of our fbody 95s were loosely called obd 1.5... has obd1 port but upgraded to II'ish software...
