header gasket question???
It also looks like you've got some serious build-up on the gasket surface, so be sure to hit it LIGHTLY with some fine grit sandpaper.
I should also mention that in some instances, doubling up header gaskets can PROMOTE leaks.
ill be taking the motor out in a few months and ill check to see if the flange is straight. there is signs of a leak but no sound of a leak. i probably did not tighten form the center out.
