Clutch problems
Old Jan 22, 2011 | 12:44 AM
1hotlt1's Avatar
Default Clutch problems
I just install a new clutch, but it's making a noise like if something is loose every time I let go at the clutch petal. If I push down it stops. Any suggestions? Thanks
Old Jan 22, 2011 | 01:32 AM
SoxXpupPeT's Avatar
did you make sure the bolt that secures the clutch fork is all the way in ? did you make sure the throw out bearing is together and secure ? all bolts and the pilot bushing all there ? there are alot of things that could cause that. if its real bad, pull the tranny out and double check it
