How do you adjust e-brake
Old Jan 22, 2011 | 03:43 AM
1C3 MAN's Avatar
Default How do you adjust e-brake
Okay i have searched everywhere and cant find much info on how to adjust the e-brake.
It goes all the way up and doesn't do anything. someone said there is an adjustment on the caliper but i'm not sure where exactly.
anyone know?
Old Jan 22, 2011 | 05:09 AM
nighthawk15's Avatar
It should tighten on its own. Are you sure the cable isn't broken or that you didn't somehow disengage it?
Old Jan 22, 2011 | 11:29 AM
97camaro383's Avatar
I had the same problem, put on new brake pads and it works perfect.
Old Jan 22, 2011 | 11:36 AM
Puck's Avatar
Is there any tension at all?
If the cable is loose you can slowly reverse and gradually pull the e-brake handle to see if it automatically tightens, or you can go under the car and rotate the adjustment nut manually - you can't miss it, just follow the e-brake line.
Rear tires should turn with very little to no resistance when spun by hand, if you tighten it too much they will be hard to turn.
**edit** Not sure if the reverse/brake method works with LT1s, but the manual adjustment method does .
Old Jan 22, 2011 | 12:29 PM
Fazz73jr's Avatar
Here you go. http://shbox.com/1/adjparkingbrake.jpg
