datalog with a/f readings
Old Jan 25, 2011 | 11:50 AM
BlackBird87's Avatar
Default datalog with a/f readings
Im trying to figure out if i can datalog with the a/f reading in the log itself instead of having a separate gauge for it. I have access to tunerpro, freescan, and datamaster and the wideband is a plx with sensor and converter. Ive got it to work with hptuners but i cant with any ltx software
Old Jan 25, 2011 | 12:09 PM
jaycenk's Avatar
Love to here if this can be done as well. subscribed
Old Jan 25, 2011 | 12:33 PM
mguidry629's Avatar
I just did mine, it can be done in datamaster. Not sure about freescan.
http://www.camaroz28.com/forums/showthread.php?t=535603
Check out this thread and let me know if you are as confused as I was. I eventually figured it out. Basically have to tap into a 0-5V sensor, best choice is A/C pressure sensor. Then go to custom data in datamaster and put in your gain and offset. If you have trouble figuring out your linear equation, post your WBO2 volt range in here and I'll help you figure out what your gain and offset will be.
you will only be able to view the data when you review it (playback), not as you're driving/recording.
Old Jan 25, 2011 | 06:49 PM
so im guessing that is my only option
Old Jan 26, 2011 | 08:39 AM
mguidry629's Avatar
That's all I know of. It's not something you really want to do permanently if you still use your A/C and I'm not sure what other sensors you can tap in to.
