Idle vid just because!
Thanks! I need to get it back to the track ASAP with the changes I've made
I put some hy-gard in it to tighten the converter a few hundred, and finally took out the 6qts of 30w dino and put 5qts of german castrol 0w30 in it with a truck filter. Re-set the lifter preload, I had over 1/4 turn on one of the intakes
I loosened up the crank trigger clearance, i was getting some weird flat spots in the datalog in the 6500+ revs. Also got an alignment the car needed it extremely badly, plus a few other tricks...Oh yea, a dry nozzle and .052 .062 .073 jets are on the way. This is a nitrous motor after all
