Getting started with FAST
Old Jan 31, 2011 | 11:42 AM
LSWHO's Avatar
Default Getting started with FAST
What do I need?
Also where can you get a baseline tune??
Very Noob questions I suppose. Enlighten me Por Favor.
Old Jan 31, 2011 | 12:13 PM
quik95lt1's Avatar
Originally Posted by LSWHO
What do I need?
IF you are keeping the stock ECM also call horsepower connecttion in WA he has a harness to interface everything........as for the tune I may have something for you...whats the motor combo its going on??
Old Jan 31, 2011 | 12:22 PM
LSWHO's Avatar
For now it's just a cam only setup. But I need to get something for tuning and I will eventually turbo the car so I figured upgrading would work best in the long run. I don't like to upgrade only to have to upgrade again. Do it once, do it right.
I'm much more in the planning/researching phase than the purchasing phase. Just trying to find the best/cheapest/smartest route. And yes, I know it isn't cheap. but I'm not planning on ever eclipsing quadruple digits so all out is unnecessary.
Old Jan 31, 2011 | 12:26 PM
speedracer2536's Avatar
I've also considered this as well but to use the stock ecu.. Is there anyway to use a crank trigger and ditch the opti completely with the fast setup?
Old Jan 31, 2011 | 01:33 PM
qc97z's Avatar
If only Fastbird was around...his T/A has the XFI setup.
I think RealQuick on LTXTech knows something about the XFI stuff as well.
Old Jan 31, 2011 | 01:50 PM
Speed Density's Avatar
hashtagBMW
Thats what I did and many others too.
Brian Macy from Horsepower Connection is a super nice guy willing to answer emails, calls and anything at pretty much anytime of the day. He built my piggy back harness for the XFI/Stock PCM combo. If I did it again I'd go full stand alone and just make a new dash. You lose tach with a piggyback.
Tony.
Old Jan 31, 2011 | 02:34 PM
If you dont mind me asking.. How much did it all run you? do you have part numbers for everything?
Old Jan 31, 2011 | 05:08 PM
hashtagBMW
I got my box for $1500 or so, dizzy was $380, crank trigger $200*, coil, wires etc + harness. Maybe like $2700 or something. I dont remember off hand.
Old Jan 31, 2011 | 08:27 PM
quik95lt1's Avatar
yep i did that on mine........now im putting togheter a cam sync dizzy out back in the intake so i can run SEFI again.....
