Strange 12 or 9
Old Feb 2, 2011 | 11:46 PM
  #41
gregrob's Avatar
What do you trap? I spray the **** out of this thing. Plan on 125ish trap w the new topend n other changes.
Old Feb 2, 2011 | 11:50 PM
  #42
Colin91Z's Avatar
Originally Posted by gregrob
******* epic statement there!
I want this bitch hanging the HOOPS
Yeah, I try to "keep it real" as Dave Chappelle would say. Now add that to your sig
Old Feb 2, 2011 | 11:53 PM
  #43
gregrob's Avatar
Im going to when I get on the computer lol. On my droid now
Old Feb 2, 2011 | 11:56 PM
  #44
Colin91Z's Avatar
I went 118 NA with my old 350ci/hyd roller combo (2500ish DA)
Not sure what it would have gone with the same shortblock/SR combo. Speculation based only on the butt-o-meter, 124ish NA. But I cant be sure, it **** the bed 3 days before the ltxshootout 2010.
I can tell you this, 118mph w/4.30s & 27" tire was no where near 7k rpm.
I'm damn near done with my 392 ci shortblock, gonna use the same heads and have LE spec me a new SR cam. If I run out of gear with a 27" tire, I'll be damn impressed.
Old Feb 3, 2011 | 12:00 AM
  #45
gregrob's Avatar
I have been running 26s but need new ones anyway.
Id be interested in your tire suspension combo. Been thinking MT ET Radial?
  #46
gregrob's Avatar
Old Feb 3, 2011 | 12:12 AM
  #47
Colin91Z's Avatar
I've run Mt ET radials, they work great, but sometimes quite tricky to launch with a 6-speed. Once your rolling though, they stick like glue. I've run two different sizes, 255/50-16 and 295/45-17.
Right now, my car is sitting on ET Street bias plys, 27-10.50-15s. Can't tell you how well they work for sure, once again due to my shortblock shitting the bed, but once again the butt-o-meter says thumbs up.
Suspension is MWC chassis mount torque arm LCA relo brackets, UMI adjustable LCAs, UMI on-car adjustable PHR. Front is stock, but with sway bar removed and Strange SAs w/300lbs springs.
Old Feb 3, 2011 | 12:23 AM
  #48
gregrob's Avatar
Cool thanks
Old Feb 3, 2011 | 12:26 AM
  #49
Colin91Z's Avatar
Cool thanks
No prob. Here's a couple of vids from LTxshootout qualifiying 2009, back then my car was hyd roller, 20cfm less heads, and had the rear susp I mentioned above but did not have the Strange coil-overs w/300lb springs on the from yet. At the time it had monroe struts w/eibach sportlines on the front. Both vids are on brand new 295/45-17 MT ET drag radials mounted on 17x9 10-spoke SS wheels.
