SBC Timing Cover on LT1 Block????
Old Feb 9, 2011 | 12:39 PM
quik95lt1's Avatar
Question SBC Timing Cover on LT1 Block????
I'd like to put a 2 piece SBC cover on my LT1......I have an electric water pump and a dizzy out back in the single plane intake (no more opti)......so i'd have to plug the opti hole in mine anyway, and it would be nice to have a 2 piece cover for easy adjustments. Has anybody tried doing this??? Do the bolt holes line up??? Or am I just better off welding up the hole in my LT cover??
From looking at pictures it looks like there's an issue with the top three bolts?? Am I correct?
Old Feb 9, 2011 | 01:11 PM
fergymoto's Avatar
You would have to frankenstein a SBC cover quite a bit to make it work on the LT1. If you want a 2 piece you may be best off to cut one in half and machine a groove in one side for a piece of o-ring to seal it to the other half... assuming it is thick enough. It wouldn't be hard to do something like that if you have access to the right tools.
Old Feb 9, 2011 | 01:30 PM
quik95lt1's Avatar
thats prob what ill end up doing......i might just machine the spot where the opti goes in flat.....then groove it and make a plug with a cover and two bolts to go in it........prob be the cheapest way out for me just be material and my time.........
