Jet Performance Module Install on LT1?
Old Feb 10, 2011 | 03:35 PM
dodge69874's Avatar
Default Jet Performance Module Install on LT1?
Alright, so I bought a jet performance module for my car for like $50 used. At that price, I figured I could at least try it out and see if I felt any difference. So, I've been searching every where and I'm still not sure how to install it. This is the one I got:
So, I believe it plugs into one of the harnesses leading to the ECM, which is in the passenger's side of the engine bay. The question is which one? Because there's like two or three of them which are pretty much the same.
Old Feb 10, 2011 | 04:56 PM
RamAir95TA's Avatar
IIRC, it can only go into one port (not sure which one). I'm fairly sure each connector is keyed so it can only go in one connector socket.
Old Feb 10, 2011 | 04:59 PM
95LTXZ28's Avatar
I believe the connectors or plugs are blue red white and black on the factory harness, it looks like your connector is a white or clear one, maybe try that port?
Old Feb 10, 2011 | 05:19 PM
TDavanzo's Avatar
I believe they are keyed I'd take a closer look at that, cant go wrong if so.
Old Feb 11, 2011 | 03:53 PM
dodge69874's Avatar
FOund on the Jet website that it connect to the one label as GREY on the PCM. Not, sure where to connect the red cable though. Didn't find a plug any where for it, and it's not mentioned on the website. Is it even necessary?
Old Feb 11, 2011 | 04:13 PM
ahritchie's Avatar
Yea, the red wire is necessary, you have to splice it in to one of the wires coming off the PCM (I think it's red also)....I forget which one specifically as I put one of these on my car way back in 1997! I don't think they even make them anymore. Don't have it on my car anymore after getting my PCM tuned by PCM for less... which is a better choice if you can afford it ($200 for custom tune)
Old Feb 11, 2011 | 05:16 PM
LSWHO's Avatar
Are those things good for ANYTHING? seriously. I know they're practically worthless, but can they do SOMETHING worthwhile?
