02 sensor
Old Feb 10, 2011 | 10:31 PM
LigHtEmUp01's Avatar
Default 02 sensor
my car has 2 o2 sensors ones on the y pipe and the other is on the driver side manifold. i just bought headers and i know ill need to extend the manifold o2 but does any one know about they y pipe. new y pipe to its ory catless? and is it worth splicing to make em longer or just buy extensions?
Old Feb 11, 2011 | 09:27 AM
jaycenk's Avatar
What year car do you have?
I only had to buy an extension for the passenger side with long tubes. The driver side din't need one. I just removed the car harness side conection from the back of the head and it reached fine.
Old Feb 11, 2011 | 04:17 PM
i havea 95 camaro but my o2's are both on driver side
Old Feb 11, 2011 | 08:01 PM
RamAir95TA's Avatar
If you have a 95, you have two O2s - one on each side.
Old Feb 11, 2011 | 09:31 PM
PAT99camaross's Avatar
definately buy the extensions i bought mine at summit racing but before i bought them i used the install kit that pacsetter gives you with their long tubes man was that a mistake spent hours splicing soldering and shrink wraping them just to have them not read properly after about 3 days ended up having to pull them back out cut out all the wire that i added re solder them and then add the extension pieces which was what i should have done first
