plug wire routing question
Old Feb 12, 2011 | 11:52 PM
1BadAsZ's Avatar
Default plug wire routing question
i finally got tired of my car sitting so im digging i deep this time trying to troubleshoot all wiring and fixing all possible problems so i can hopefully get it running again. however i do have a question cause ive had plenty problems with arcing wires and coil n such. im swapping to coated headers and also otvc wires as well as heat sleeves. my main question is when routing them from the opti to the plugs is it ok for them to touch or is that a no no too?
Old Feb 13, 2011 | 03:58 AM
SS RRR's Avatar
Village Troll
Absolutely not. Even with heat sleeves if they touch a primary the wire will burn quickly. I would suggest leaving the heat sleeves off since it does nothing more than take up more room from the already limited space.
