valve spring questions
Old Feb 15, 2011 | 06:21 PM
95T-A's Avatar
Default valve spring questions
I've been reading up on valve springs ,and the more I read the more worried I get about it. I've got a couple questions. The first one is will the patriot gold spring kit be good for the lunati 60121? Next I understand how you measure the installed height and all that with the micrometer ,but once you take it out and put the spring in how do you know it's still at that height(Im doing this with the heads off)? Maybe I've just been thinking to hard about it lol.
Old Feb 15, 2011 | 08:01 PM
RamAir95TA's Avatar
Once the spring is installed the installed height stays where you set it.
Old Feb 15, 2011 | 08:13 PM
95T-A's Avatar
Ok so maybe he question I should be asking is how do I set it and make sure its where I want it. This is probly in the guides but I dont quite understand it..
Old Feb 15, 2011 | 09:22 PM
Wicked94Z's Avatar
you need a valve spring micrometer. goes between the seat and retainer and measures the spring height. You can move it around with shims under the seat, +/- locks, +/- retainers, or changing valve lengths.
