Emissions/Header Question.....
Thanks.
Here is a suggestion, by some stainless Ebay headers and have the smog fittings, added then get them coated. Any good welder can do it and better and cheaper than some will rust headers. They may be more of a hassle to install but I would not put another pair of p@c*$h!tt*rs on my lawn mower, let alone a nice car. The Y sucks, they rust, even the coated ones rust, more so if you drive your car a lot in all WX conditions. The things they do have going for them is they fit without many mods, prep pretty easy, tuck up pretty good, and do gain some HP, but that is about it, the same for most LT headers. To bad they did not jump on the bandwagon and produce some stainless pipes at close to the same price point as they make the rusty ones, then they would be worth it.
Buy some stainless ebay headers, pre install them, mark them, make any mods/dents you need, add the fittings you want or need (maybe even reuse some of the stainless stock stuff), add some stainless mini cats in the ORY and then send them off to get coated if you want. You will then have some good looking lifetime headers that will need a occasional re-coat when the coating burns off, for around the same price as the headers you were looking at, with the best ground clearance, (if you stagger the mini cats) you can get.
Good luck with whatever you choose to do.
Dub
Dub
