How much hp?
Old Feb 24, 2011 | 04:01 PM
killerz97's Avatar
Default How much hp?
383 lt1
eagle forged crank, 6" h beams, srp -6cc pistons
CR around 11.75
mild port heads with valve job
Patriot exteme valve springs
LE custom grind 234/242
PRW 1.6 RR's 7/16 NSA
42lb injectors
The car is an A4 and will be getting either a 3200 or 3600 stall and has 3.23 gears. Any estimates on hp/torque?
Old Feb 24, 2011 | 04:09 PM
gregrob's Avatar
There is no possible way to guess. The heads could be decent or worse than stock.
