Engine swap tips needed
Old Feb 15, 2004 | 09:32 AM
Darth Z's Avatar
Default Engine swap tips needed
I am about to do a swap on a 96 T/A and can use any tips I can get. I' ve never done a swap on a 4th gen, so it' ll be a whole new experience. I know the best way to swap it, is from the bottom. Unfortunately, it doesn' t look like I will gain access to a lift to do it. Without a lift, there is probably no way to get the car up high enough to pull the engine from the bottom, right? How about pulling it from the top? I know it' s more of a PITA, but what would I need to do in order to pull from the top? The hood would have to come off, but I' d also have to pull the radiator, right? What else would have to come off? Any and all help will be appreciated. Thanks in advance.
Old Feb 15, 2004 | 10:41 AM
kevinb's Avatar
I did a lt1 swap on my v6 a year ago. We got it high enough with a cherry picker. Put the rear tires on some old rims/tires to get it up higher. Then lift the front frame with a strap around the radiator support being carefull not to bend it. Put GOOD jackstands under the beefy unibody rails and maybe put some other rims or something under it incase it falls. Then we put a couple floor jacks under the engine and tranny and dropped the whole works out from it and rolled it out with the jacks and wheels still attached to the suspension. If you have any other questions just ask!
