True Duals with Summit X Pipe Kit?
Old Feb 28, 2011 | 01:30 PM
Mguncowboy's Avatar
Originally Posted by IronOutlaw
How loud are the Xr1's vs the 1 chambers? Did you use the oval or round cased ones?
I used the oval and they fit perfectly. They actually fit better than the single chambers. The XR-1's are still pretty loud, but definatly way more tolerable than the single chambers. I've never regreted going to the XR-1's from the Single chambers and my neighbors appreciate it too. If your running cats the XR-1's will be at a very tolerable range with good tone. No cats and their on the loud side but not to loud.
Old Feb 28, 2011 | 01:35 PM
Mguncowboy's Avatar
Originally Posted by sweetbmxrider
You running a stock style torque arm setup or what?
Like the other response said - u have to use a stock type torque arm or your ground clearance becomes an issue. I'm using a stock type BMR torque arm with no issues at all.
Old Feb 28, 2011 | 10:45 PM
jkr2wld's Avatar
I have almost everything to put my camaro into surgery all i need is the mufflers (Gonna go with borla XR-1's) please please don't tell me I need that panhard bar relocator kit to tuck it up if I dump them. thats another 200 bucks i can put to the shop to put it up. I have long tubes 2.5" summit x pipe arp bolts and felpro gaskets... can it work with out the relocator kit or is it just an insurance?
Old Feb 28, 2011 | 11:07 PM
hitmanws6's Avatar
Why you need a Panhard relocation for dumps? Unless you mean you want to go over the axle. Then the answer is most likely no. A competent shop can do 3 inch over the axle with no relocation
Old Feb 28, 2011 | 11:50 PM
gregrob's Avatar
You can also do them with a tunnel mount, just takes a little bending.
Old Mar 1, 2011 | 10:59 AM
Formula383's Avatar
Hmmm...ideas
Old Mar 1, 2011 | 01:27 PM
jkr2wld's Avatar
sweet just making sure
By Brett Foote | 2026-06-04 05:00:17
