gas in ccv tube
pulled the ccv elbow, had white gunk and a strong smell of gas. cleaned it out.
drove around for about 10 minutes(to the parts store) pulled the tube off of the TB, and about an ounce of liquid gas literally poured out of the tube.
is this normal? I keep reading about how people put filters on the tube so that oil doesn't get into the TB, but what about the other way around?
is this indicative of other problems?
I don't want this to be too long, so I'll answer any questions, but I don't want to type out the full background of the car in the first post.
it's worth noting that the gas and oil mixture gunks up on the elbow, keeping the gas from flowing into the engine(thank god) though currently it also keeps the valve cover from venting, so this needs to be fixed asap.
basically I need to put
http://www.amazon.com/Fram-BA6592-FR.../dp/B000C31J3C
on it as soon as possible, yeah?
or will that not keep the gas from flowing?
I thought I might have a clogged injector maybe(just a theory, considering I shouldn't really have that much liquid fluid in my intake at any point, much less in that tube) so I threw some seafoam in it.
I also ended up changing the actual pcv valve, a day later, it was full of oil and stuck open.
I mention those two things because 1. they might have had some affect that changes the situation now and 2. the car has actually been running WAYYY better since I did it.
like, I would drive it 5-10 miles and it would run rough as hell and eventually die while I watched the voltage slowly drop(though the alternator and the battery repeatedly tested as working fine). now it's running great.
anyway, I'll work on getting some pics, hopefully that info is in some way useful.
Post up pics. It may clear this up.
if you need a more specific picture or if you just need to know something, I'll do what I can to help out. unfortunately I only have a 1.3 mp cellphone camera to work with though, so you'll have to bear with me on that
.I'd also like to note that when I went out to take the picture I popped off the tube and no gas was in it, and the elbow was oddly cleaner than I'd even left it, so I really wonder if the stuck pcv valve had something to do with it.
that still wouldn't really answer why I had such a ridiculous amount of liquid gas not only in some part of my intake, but enough to actually get somehow sucked into that tube.
and it was FOR SURE gas, I mean condensation or anything else would be bad too, but this had a strong gasoline smell...I mean, that's what it was.
which sort of leads me into my next question...the original owner did a LOT of upgrades to this car before I got it. some of them smart, some of them not so smart. supposedly the entire engine has basically been built up to lt4 specifications with the exception of the intake(and possibly things like coolant passages), one of the things that were mentioned were that it had a ridiculously big TB size(58 mm) and equally big injectors(34-36 lbs).
the car has gotten fairly atrocious gas mileage since I bought it, even for a camaro. roughly in the 5-7 mpg range. is it possible that with different injectors and a stock pcm that my engine might just have gas pouring into it at retardedly high rates? is there any way to check specifically what injectors I have? I was honestly kind of hoping the previous(2nd) owner was either lying to me to sell the car, or was misinformed. any help would be appreciated.
p.s. sorry this was so long.
Take a pic of the drivers side of the engine.
http://img269.imageshack.us/i/0301111602.jpg/
http://img822.imageshack.us/i/0301111603.jpg/
http://img534.imageshack.us/i/0301111601.jpg/
that should give you a pretty good idea of everything that's going on.
honestly I don't know what I'm supposed to be seeing, I had an '88 TBI camaro for years and I could tell you damn near anything you wanted to know about those cars, but this...I dunno where to even look for the evap, much less whether or not I have one.
I know I'm veering off topic again, but if anyone can give me any information about that intake it'd be very helpful to me. Specifically if that's a common look for k&n cold air intakes, is it common for people to have to remove the fender wall to get the filter to fit? That seems kinda crazy.
anyway, I still would like to know what's going on, if the evap is missing maybe that'll give me a clue.
also, I pulled the hose off again today, no liquid, no strong smell.
that big black box, or
http://www.shbox.com/ci/ci260-2.jpg
that little black...thing?
I apparently have neither.
I say "now" because I bought a cap for the bottom one the day all that went down, it hadn't had one up to that point.
would leaving that uncovered have caused...anything? I mean, could gas have evaporated out of that hole or anything?
p.s. thanks for all the help, seriously.
