Cam only 355 dyno numbers
My list of major mods:
355 stock bottom end/forged flat tops
COMP 280XFI (467 cam)/1.6 Pro Mags
52mm throttle body/Moroso CAI
SVO 30# injectors
Jet Hot long tubes/2.5" true duals/Dynomax bullets
FLT Level 4 4L60E/Yank SS3600
Moser 9" rear/3.70/Detroit Locker
Accel 300+ ignition
CSR electric water pump
Underdrive crank pulley
That's about all I can think of. If there's anything else that may make a difference, ask me. I'll post up my numbers and graphs in a little bit.
my cam only, stock shortblock made 325rwhp through an unlocked auto. (CC503, Pacesetter Mids, Intake, etc)
My best pull on motor was 332/348. I did another pull that has a few more hp, but I think it was getting heat soaked because torque was way down. We also did a couple pulls with the nitrous. When we tuned, I didn't have a bottle with me, so the spray tune is relatively safe (5 degrees taken out, base afr a little fatter). With the spray tune loaded up, I made 466/465. Overall I'm pretty happy with the numbers.
Then again, as long as it performs well at the track, which is does, I am happy.
I meant I didn't have a bottle with me when the car was tuned 2 years ago. So for a spray tune, he just richened it up and pulled 5* of timing out, so it's just a generic safe nitrous tune that was never checked.
Just curious, what makes you think it's detonating on the nitrous pulls? Liek I said I'm not getting any knock, but I'm also on 93 octane pump gas. Maybe I should use 100?
