problems again
Old Mar 1, 2011 | 08:34 PM
93z28ltone's Avatar
Default problems again
So I was driving my car last night and had s2000 try and a fly bye so punched it I let off at a 120 and was 3 cars in front of him I noticed when I let my belt squealed like crazy so I got on it again and noticed that it does it every time my car shifts at high rpms I also noticed that my voltage Gage is bowncing up and down like crazy any advice would help
Old Mar 2, 2011 | 09:03 AM
Gojira94's Avatar
Sounds like you've got a problem with either the belt or tension on it. That could be:
-Worn belt slipping at the RPM change, causing your alternator to dance
-Weak tensioner allowing belt slippage
-An accessory/ pulley binding due to bearing wear
Check the belt, pull it off, feel the pulleys and see if any of them have more than normal resistance or feel lumpy/ notchy.
Old Mar 2, 2011 | 09:11 AM
myltwon's Avatar
^what he said
Old Mar 2, 2011 | 11:03 AM
93z28ltone's Avatar
OK I will do that this weekend thanks
Old Mar 2, 2011 | 11:21 AM
SoxXpupPeT's Avatar
it could be that or a bad alternator thats starting to lock up at high rpms' causing the belt to squeal... Check your tension and belt first tho
Old Mar 2, 2011 | 11:24 AM
Matts94Z28's Avatar
Mine does the same thing. I replaced the tensioner and checked all pulleys... still does it. I just haven't taken the time to throw a good belt on their.
Old Mar 2, 2011 | 12:49 PM
93z28ltone's Avatar
had the alternator a week or so ago and it should good so i will change the belt and check the tens and other pullys
